It is currently Mon Sep 15, 2025 12:48 pm
PostPosted: Sun Jun 02, 2024 2:55 pm
First name: Jon
Last Name: Snider
City: Colorado Springs
State: Colorado
I just cut the top and back channels for bindings and purflings with the LuthierTool unit. Because of the size of the bearing wheel, it didn’t fit entirely into the cutaway area, so the channels are not wide enough.
Unlike other areas where I will just use a file, that won’t work on the inside curved area.
I could maybe try a curved piece of emery board.
Or maybe a gramil followed by perhaps a chisel.
Anyone been down this road with a good option?
Thanks. Jon
PostPosted: Sun Jun 02, 2024 4:57 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I've used a short section of kerfed lining with adhesive-backed sandpaper on the back/webbing side to do something similar. The kerfed lining is flexible enough to conform to either inside or outside curves. How much wood do you need to remove to get to the target depth?
These users thanked the author J De Rocher for the post: Duct Tape (Sun Jun 02, 2024 10:06 pm)
PostPosted: Sun Jun 02, 2024 5:03 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have used a gramil and a chisel to cut a binding ledge where I couldn’t reach with a router. I did the chiseling much like you would mortise a door hinge making close cuts across the grain and doing several shallow passes of that to get to depth. The gramil marked and defined the outer edges of the cuts. I imagine one could do a whole guitar that way but it would take a while.
These users thanked the author bobgramann for the post: Duct Tape (Sun Jun 02, 2024 10:07 pm)
PostPosted: Sun Jun 02, 2024 5:20 pm
Last Name: Kincheloe
Riffler file https://www.ebay.com/itm/275559797534
These users thanked the author DennisK for the post: Duct Tape (Sun Jun 02, 2024 10:07 pm)
Users browsing this forum: Bing [Bot], Melt in the Sun and 82 guests
